Sending of password for user g_timpe@sbcglobal.net did not succeed. Mail server inbound.att.net responded: Server error - Please try again later.
  • 8 views
  • Last reply by Toad-Hall
My email provider is AT&T Yahoo and I cannot get the email to download into thunder bird. See subject for the error message.
Yahoo and AT&T have recently changed how they allow Authentication.
  • Select 'Menu app icon' > 'Options/Preferences'
  • In 'Options/Preferences' left Pane select Privacy & Security
  • Select checkbox 'Accept cookies from sites'
You are probably already using these server settings, but you may not have changed the 'Authentication Method'.
Server Settings: IMAP Incoming server name: imap.mail.att.net Port : 993 Connection Security: SSL/TLS Authentication Method: OAuth2 User Name - Enter your full email address.
SMTP Outgoing server name: smtp.mail.att.net Port :465 using Connection Security: SSL/TLS Authentication Method: OAuth2 User Name - Enter your full email address.
then restart Thunderbird. Yahoo will prompt you to logon to allow thunderbird access. then a token is created and stored in thunderbird which it will use from then onwards.
